real time New Alt still no charge
89 22RE pick up 4x4 5spd
Replaced alternator and still no charge. Will start and run on battery.
Checked the two fuses I that the owners manual said are in the charging circuit.
Real time help please! need to get ol' Bessie running.
Apppreciate any advice on things to check.
Thanks
original? crapped out about 9 months ago.
replaced it with one from Advance Auto and that worked fine until a week ago. Driving on highway turned on the lights and they started to go dim. Got off and it died completely. no juice left at all.
Figured it was the same problem again, charged batt. drove to Advance, their test showed no charge coming from alt, so replaced under warranty. put new one in and still nothing.
Replaced batt terminals, + was pretty corroded inside.
Seems to be charging now- measures 14.5 V across the terminals when running and only 12.5 when not.
Thanks for the help.
Make sure your ground strap is good too. You have to have a good ground in a 12v system or nothing works as it should.
This is true,
Return that Alt.
