Other than cutting it out, I would try this:
Clamp a vice grip as tight as you can get up near the front end where the tbar starts to get thicker and the vice grip can't slide forward. Use 2 vice grips if you have them, up against each other for double the holding power.
Then wrap big ratchet strap around the tbar and up against the vice grips so it can't slip. take the other end and fasten it to something solid up near the front of the truck or better yet a tree about 10 feet away. Crank it tight to put a strong pulling force on the tbar. Heat the back socket with a torch and get it as hot as you can get with a propane torch (watch out if you are using oxy acetelyn). Once it is hot, blast it with PB or an alternative and than tap the socket lightly with a ball peen. Keep tapping and blasting with oil with the pressure applied and hopefully, maybe, it will slowly come out, one tap at a time.
Good Luck!!!
Good Luck!!!
