semlin
curmudgeon
so i am installing the intake camshaft right now. my question is whether the valve position matters because the cam seems to be sitting very high at the front of the motor and I am afraid to bolt it down.
when i got it back from the headshop they had loosely attached the cams and had them aligned so the single dot on the cams was at the 25 degree angle instead of the double dot specced in the manual. rather than rotate the cams with the holders only half way tightened I just took them off. Now I am worried they have set it up with the valves lined up wrong as when i lay down the cam at the correct angle with the double dots lined up it lies down at the back and sits quite high at the front.
any help appreciated
