I am in the process of regearing my rear axle to 5.29's Yukon brand. I purchased them from specter b/c they were the only ones that had them. The instructions are generic and they say nothing specific to the 80series diff. Diff gears that I have set up in the past have a CD "checking distance" scribed on them. That gives me a idea of where I need to start regarding pinion shimming. The yukons dont and I set them up using the same shims that were in the factory gears. After doing this the bluing told me I was way to deep. I set them to the min shim listed in the FSM and it also told me the pinion was too deep.
So then I called Randy's ring and pinion the owners of Yukon. A guy in their install shop said he starts with a .015 shim on the pinion. That would be 1/3 the thickness of the thinnest factory shim.
Can anyone confirm this?
Thanks
Kirk
Thanks
Kirk
