Razor One,
That looks pretty sharp! keep up the good work, i'm kicking around the same idea!
Cheers!
Dan
Cheers!
Dan
Razor One,
Cheers!
Dan
Most of the premium rod manufactures make a "moisture resistant" 7018 rod, like Lincoln, Hobart and ESAB. They have an R or MR suffix. They would still need to be stored properly for a low hydrogen weld, but they won't go bad as fast in a high humidity environment like Houston. Making a bumper isn't going to require a low hydrogen weld.
6010 will be fine and you have a good hand for it, but it will take more work to finish the beads for a nice cosmetic appearance. That won't matter where it doesn't show.
Looking good. If that is 7018, it looks like you are whipping it like the 6010. That 7018 runs real nice and smooth without whipping.
It will have that "oil rig" look to it.
Ditch the 6011 and use 7018. It gives a nicer looking smooth bead so you won't have to do so much grinding to finish it.
Nice! No offroad bumper is complete without a bottle opener![]()
