It's been awhile... Glad to be back...
Before work, i attempted to remove the radiator fan without success. I'm at work now and I'm not sharp enough at the moment to figure out how to prevent the fan base from rotating as I loosen the 4 bolts. I need to remove the fan to replace the radiator. The belts aren't tight enough to hold the pulley in place as I wrench on the four 12mm bolts.
I might be missing something obvious.
Any hints or tips will be appreciated before I tackle it again after work.
Thanks.
Thanks.
