The drain on the rad. is a PITA to get to and makes a mess when you get it open. At least on my aftermarket radiator.
If I could find a 10mm (i think) drain cock, install it into the drain hole, would I be making more problems than I have now with having to replace the plastic drain plug every time I cross thread it?
It would stick out a little bit. The skid plate (if I ever reinstall it, broken bolt) should save it from below.
