Before putting the intake manifold and all that on the car, I put the injectors into a flow bench to test them out and see if any needing replacing. They all flowed within 4 percent of each other, which is pretty good, so a cleaning, reseal, and reinstall is all they needed. Being the anal bastard I am, I put them on the engine with the lowest flowing on cylinder 2, then increasing clockwise around the motor with the highest flowing on cylinder 1. This is the flow of the coolant, so the coolest cylinder will be 2 and the hottest 1. This way, the hotter cylinders will get a little more spray under WOT to help cool them down. Is it enough to make a difference? Maybe not. But I feel good doing it so yeah.
Next I tackled the park/neutral switch on the 4l60. When I tried to get the harness off originally, the plug was fused to the switch. I had to break the switch off to get the harness off the transmission. This is what was left:
I picked up new harness connectors for the park/neutral safety switch. This is apparently a common issue. Upon dissecting the plug, I found that the dielectric grease in the plug had melted and reconstituted itself into some kind of thick pasty super glue. I guess it's from being near the exhaust for 200k miles. The new plugs came with wires already, but they didn't match the factory colors. I went to de-pin the old connectors to transfer just the new plug bodies over, but the pins were stuck in the old plug with that dielectric goo. So I ended up having to carefully cut apart the old connector and get the pins out, clean them, refurbish them, then insert them into the new plug bodies. All better:
I also thinned out the engine harness, and rewrapped it with Techflex F6 flame retardant woven wrap. I used Tesa tape to button it up. I like the euro look for harnesses, and the crappy looking plastic corrugated loom from the factory was falling apart. Here you can see the harness. And OH NO! What happened to those shiny new Summit exhaust manifolds!
I'll go over what I did to the engine harness when I post about the electrical. That's going to be a pretty long post.
The engine and everything is now finally ready to put the body back on the frame. It has all new body mounts. Hopefully this upcoming week I'll have a rolling FJ off my rack.
