I used the R452 syncro gear as the R151 was just different enough that it would not work.This is why I say you need ALL the gears and springs that touch the 5th counter gear.
Awesome! I'm nearing the end of a long saga with my transmission, will have to post up details here once I've finished. If you're going with a 5VZ bellhousing wouldn't you be better off to use a 5VZ flywheel and clutch also? Not sure what the differences in length, throwout bearing and starter teeth/diameter are, but it might not be compatible. BTW, I have a spare 5VZ bellhousing, not sure what shipping to Ohio would be like though.
| Landcruiser | HZJ79 | 8/1999- | 1HZ Diesel | 33428-HZJMOD | Gear Set 5th Modified | Ratio .711 from .838 |
Landcruiser | HZJ71 | 8/1999- | 1HZ Diesel | 33336-35100M | Gear Mainshaft 5th | R150F/R151F Transmission Modified Fully Splined |
So...I just noticed when shopping for transfer case gears, that Terrain Tamer list a 5th gear ratio change kit for the HZJ78 etc Land Cruiser (R151F trans)!
Not quite as high ratio as the .695:1 R452 gears ratio achieved when installing those gears into an R150/R151, but pretty close!
Landcruiser HZJ79 8/1999- 1HZ Diesel 33428-HZJMOD Gear Set 5th Modified Ratio .711 from .838
Has anyone heard of these or had any experience with them?
They also offer parts for the R151 that are upgrades such as fully splined shafts etc. Sounds like the mods that 360GearboxesAndDiffs does to their trannies, yet will not sell just the upgrade parts separately.
Landcruiser HZJ71 8/1999- 1HZ Diesel 33336-35100M Gear Mainshaft 5th R150F/R151F Transmission Modified Fully Splined
Transmission & Driveline Catalogues
Australia's largest range of 4wd 4x4 four wheel drive aftermarket replacement parts and accessories stores in Melbourne Sydney Brisbane Perth Adelaide Darwin Alice Springs Auckland New Zealand Fiji Recovery Gear Suspension Electric Winches and hard partswww.terraintamer.com
So I've picked up over half of the parts of an R151F 86-87 22RTEC trans, missing rear housing transfer adapter and many small parts (I got all the gears and main case, all for the average cost of just the 22RTEC R151F bellhousing), and am keeping my eyes out for a deal on an 88-95 R150F transmission (even with broken gears) to swap these gears into.
This is in addition to my land cruiser R151F version with the passenger drop rear transfer case which is slated to go into my Suzuki Samurai LWB project VW 2.0mTDI swap project. I'm looking at importing a complete left hand drive Samurai LWB currently, as opposed to spending $1700 on OEM body panels and 2x4 steel tubing to stretch the body and frame on my SWB US-market '88 Samurai... The spare trans could possibly be slated for chopping my existing rusty Samurai body into a removeable hardtop pickup cab + a Suzuki Carry or Mitsubishi Sambar 3-tailgate style "ute tray" utility pickup bed cut down to 64".
It appears that one of the two gears required to do the R456 overdrive swap on the early style R-series trannies is definitely never coming back in stock again unless Terrain Tamer happens to manufacture their overdrive upgrade kit for the early versions (unlikely) in addition to the kit they make for the 1996+ transmissions, so it looks as if the only thing available for the 1985-1995 R150/R151 trannies to upgrade 5th gear from the stock 0.838:1 is the 0.790:1 AX15 5th gears and a little machine work. Either machining up a spacer, or having the stub extension one side of the smaller gear hot wired and surface ground off...
0.838:1 vs 0.790:1 is about a 150RPM difference as calculated with 31 inch tires and a 4.10 differential ratio. Not as drastic as the R452, but might as well do this mod if you are tearing apart the trans anyway.
Read up on this mod a bit, but the info is a bit harder to dig up. The one guy who had a nice write up on it, I cannot locate the link to at the moment, but he was talking about machining up a spacer, and also about the cluster ratios and why the R154 5th gear does not work out for a good ratio due to the R150 or R151 cluster ratios. Cluster ratio = input shaft gear tooth count vs the 1st gear on the main one-piece cluster shaft with all the gears on it. The differences in each gear (aside from 1:1 4th gear) all must be multiplied by the input gear cluster ratio to get the actual transmission final output gear ratio.
Here is what I found from a quick search. I am not sure this will work on all of our R-series trannies, please research before buying:
Cobra part # 462585
Cobra part # 462585K
More info on the AX-15 5th gear swap in Posts 15, 17, 21, 29,31:
Note the mention of different inside diameters between the one AX15 gear vs the later R150. Do your homework here, as not all years swap, but it looks like the 85/86-95 R150/R151 transmissions "probably" all can fit the AX15 5th gears with mods. Either having the one AX15 gear cut down via EDM + finishing on a surface grinder, or else machining a spacer to adapt it as one person mentioned in that link.
So far I believe I have read two counts each of people installing the AX15 gears in the earlier transmission by cutting and grinding or just grinding down one of the two AX-15 gears to remove the integral hub on one of two sides, and two as well who have machined some sort of spacers to make them fit.
I'm having a little trouble understanding how adding a spacer to a gear that is already too wide will make it fit as an assembly, but these 2 people have reported they have ran it this way and it works.
EDIT - I believe the spacer machining method works because there already appears to be a spacer on the this 85-88 R151F transmission which has been fit with the AX15 5th gear in this photo, and so I'm assuming that you either simply chuck up the spacer in a lathe and cut a step on the ID on the front end of it to slip over the AX-15 gear's shoulder, or else just shorten up the spacer in the lathe to compensate for the additional should on the AX15 gear vs the R150 only having the shoulder on the front side of the gear and not on the rear.
I did some numbers crunching for RPM savings.
Compared to the stock R150/R151F 5th gear ratio of 0.838:1, dropping down to a 0.790:1 5th will save you 151 RPM @ 70mph on 4.10 gears and 30.8" ("31-inch") tires with a 1:1 high range transfer case gearing.
The taller the tires or the taller the diff gears, the less RPM savings you'll have, but for a heavier rig, this puts you out of the range of efficiency of smaller turbodiesels with a single turbo, such as 1.9TDI VW swaps in front of Toyota trannies. But even on 35's with a 4.10 gear (say you're running a 1HZ or 1KD, or OM606 or OM617 swap, or a lighter 1.9TDI swapped rig such as a Samurai or CJ3 CJ5 CJ7 etc), 35-inch tires and a 4.10 will still yield you a 70mph RPM reduction of 134rpm - 2,195rpm @ 70mph. Not quite the savings of running one of the several generations of the 1996+ R452 gears in one of the several revision versions of the 1996+ R150 and R151F transmissions, which would allow you the same highway RPM but a much deeper 1st gear and low range via a deeper differential gearing, but if you have the 85-95 R-series transmissions, this is a great option if you already have the transmission apart for servicing or upgrades to Marlin Crawler parts...
