This is my first post, and I thought I would share what I found today. My son's '77 FJ40 lost its clutch slave today. It was spraying fluid out the dust protector bellows when the pedal was depressed. After taking the slave off the passenger side, we found the piston was bottomed in its cylinder. Pushed it out with compressed air and found a slight ripple or crease in the cup (there was only one cup on the piston, although it looked like there was room for two). The wrinkle in the cup revealed a very small hole that was allowing the pressurized fluid to escape. We couldn't find a local replacement as he needed to drive the truck to work in a few hours. After running a brake hone with some WD40 down the cylinder bore and spraying out the residue with brake cleaner, the cylinder appeared to be in pretty good shape with no bad rusting, so we just needed a new rubber pressure cup for the piston. After measuring the bore of the original slave cylinder, we found it to be 13/16's. Went to Advance Auto and found a 1994 Toyota slave (Perfection Performance brand) part number 37525 for $12 IN STOCK at the store. Took the new piston out of that part and used some DOT3 to lube the old cylinder and new piston and installed it. The new piston had two pressure cups on it. We left the assist spring on the end of the new piston. Bolted the unit back in place and it sealed and worked just fine. I did have to adjust the linkage to provide more freeplay, which must have been caused by the new piston not being drilled as deeply for the adjusting rod as the original piston, as the pistons looked to be identical in overall length. Anyway, I'm sure it would have been better to replace the cylinder, but when you need to get your truck back on the road, and you don't have a factory replacement handy, this process will get it done in under an hour using a part that virtually every Advance Auto keeps in stock at each store.
