LINUS
Waiting for the Great Pumpkin
Thought I’d post this so new owners can splash oil on ”Day 1” of a 5.7 / 3UR when they buy a used one:
Oil pan drain plug: 30 ft/lb
Stock filter cap: 18 ft/lb
Filter cap drain plug: 9 ft/lb
The smaller O-ring is for the filter cap drain plug.
Recco’d oil is 0-20, but as of my last change I went 5qt 0-20, 3qt 5-20.
Valvetrain noise on startup is sub 2 seconds & I leave mine sitting for 2-3 days at a time.
I never got used to the pure 0-20 oil startup noise, and I live in a relatively colder area of the continent.
FWIW, I use Mobil 1 & the 5qt 0-20 jug was “Extended Performance”
the remaining 3qts were 5-20 in their “High Mileage” -flavor.
I’m probably making some “2-20” weight with my viscosity blend.
1st oil change by me was at 58K, and I replaced my filter cap with a Jowett one - can’t say how much I like it compared to that stock POS.
****If you buy / are servicing using a Jowett cap, TQ values stay the same.****
HTH helps others / use as a quick ‘cheatsheet’.
