The new tires rub at full compression in the rear, so I dropped the bump stops 1.375" in preperation to add the L shocks. Pretty simple, 3/16 x 2" flat stock on top and bottom, 1"x1" square tube in the middle.
FJBen said:Thats what I'm getting steel for today and I'm going with 1/4" wall just to be safe.
alia176 said:Forgive me, but why not simply go wtih 2"x2" or 1.5"x1.5" tubing and longer bolts? I think most of us are simply going with a 2"x2" tubing for extensions. Just a thought!
alkaline747trio said:Used what he had? Looks functional if nothing else.
BTW, is the rear the only place the 315s rub at full stuff stock?
alkaline747trio said:So 315's really do fit on a stock rig?
FJBen said:I think that's pretty subjective...LOL...yes they do "fit" but definitely is not optimal. There will prolly be enough rubbing to catch hard sometime and possibly rip a flare off. The 285's/305's seem to be about as far as I would run on a stock suspension.
FJBen said:Another thought is that the bumpstop is made of rubber...so you will get some "squishyness" with it. I'd imagine you are giving up less than .5" by the time it's said and done. Especially if you are coming down hard off of something to stuff that tire, i'd rather have the fudge factor.
The suspension has enough travel that .5" upwards loss isn't going to make any difference.
FJBen said:The front I would try and get as close as possible...LOL
alkaline747trio said:So the rear is the only place that gets the rub?
Mickldo said:Can you post some pics of the front ones as well?
