Howdy,
A few weeks ago I picked up my truck from Jim Dickey's repair shop, and it's running great. There were no apparent oil leaks when I dropped it off, and none when I picked it up. I know because around this time I had been inspecting it for anything wrong.
Fast forward a few weeks; I'm camping with some friends and shortly after arriving at the campsite, about 5 - 10 minutes after I turned the truck off, the top rad hose burst and sprayed coolant everywhere. Immediately turn the key to ignition to activate the (stock) temp gauge, and it goes about 2/3 or 3/4 the way up. Approaching the red, but still decidedly below. Hose was very soft and old, so assumed to be the culprit.
Burped it a few times, swapped out the rad hose, and refilled it. Required some more burping to get the rest of the air out. Been driving fine since then, without issue.
About a week ago I decided to clean up the engine bay to remove any antifreeze leftover from the burst hose. I used a standard engine degreaser as well as Simple Green, and feel I was pretty liberal in application. Now I'm getting oil and Power Steering "leaks" where before there were none. See photo of DS inner fender. There used to be no oil or PS spray here. Now there's both.
I'm wondering if I actually screwed something up or if it's residual, uncaptured oil that was 'loosened' up by the engine degreaser. The line of the oil spray seems to be coming from both sides of the belt. I will keep an eye on it and hope that it diminishes, but the quantity seems a bit concerning. This photo was taken after about 10 miles of driving - I had cleaned it prior.
Thanks for any feedback!
