Assuming that the fairlead rollers are changed over to polyurethane, does anyone see a problem with using synthetic line on PTO?
I already got 125' of Masterpull's 3/8" and thought of using it on my PTO.
............. the only things the cable doesnt like is heat,UV, and mud in the fibres........
Gee, I'm convinced. (Sorry, I couldn't resist. No disrespect intended, but the "advantages" of synthetic rope just don't appeal to me on a winch. To me, a winch cable should be practically indestructible.)
But the reality is, they aren't. Even wire rope needs to be taken care of. Kinks, splinters, stored energy, cleaning and lubrication.
Very true, but for these cautions for synthetic rope:
have little, if any, effect on wire rope. Synthetic rope out - performs wire rope in some areas and is easier to work with, but IMHO for overall performance and ruggedness, wire rope is a better choice for the way most winches get used. But if you're handling winch lines all day long and money is not an object, sure go synthetic and carry a few spare winch lines in case you damage your rope.
The wire/synthetic argument is approaching the levels of the Chevy/Ford argument. .......
........No need to carry extra in case you damage your synthetic. Learn how to repair it, in the field. ............
Synthetic line that has visible damage can be repaired in the field as you say. But what about UV damage or heat or dirt/mud in the fibers?
I've seen too much of what UV light does to synthetic material that's exposed to it over time.
You can minimize the exposure to these elements, but we're talking about common things that we deal with in everyday life, as well as wheeling: sunlight, dirt and mud. That is why if I was running synthetic rope, I'd carry at least one spare rope that was stored properly - protected from sunlight, dirt and heat.
I'm well aware that there are definite advantages with synthetic rope. I'm not debating that. I just think that considering the way most people today use their winches, wire rope would give them the most bang for their buck. Less maintenance, potential issue with the rope are usually visible, and the rope is less affected by natural elements on the trail or even sitting in your driveway.
