I'm trying to remove a PTO from my parts FJ40 ('71) to my project FJ40 ('72). I've removed the 5 bolts that hold the PTO to the tranny and have disconnected the e-brake, odometer cable, electrical connections, PTO shifter linkage, front and rear driveshafts. When I first removed the 5 bolts the PTO separated from the tranny about 1/4 of an inch. However, I'm not able to separate it any further. I've tried inserting a ball joint separator into the opening to see if I could pry it off, but had no luck. Should the PTO be in a specific alignment in order to slide it off? Should I use a jack to push the PTO weight off the input shaft and then slide it towards the rear of the vehicle?
Thanks for the help,
Kevin
Kevin
