proportioning valve location
Little Rock AR
I put an axle from a 1977 on my 1970 Fj40 for the disk brakes. I just got the proportioning valve from SOR but Im not sure where its supposed to be mounted. I have the body off the frame right now on mine and cant see a logical location for it to go. If someone has a picture of a 76 or later proportioning valve mounted up please post it. If no pic but you know where its supposed to mount that will help too. Thanks
Here is the pic, hope it helps.
Another option you can do is you can use an unboosted corvette master 75 or 76. You do have to fab up a mount due to the corvette using a 3 bolt pattern...pretty easy to make. I've got this set up on my 4wheel disk set up and it is great, no proportioning valve needed.
