- Thread starter
- #41
Thanks. But what do I have to lose? Can't do much worse than the rust already has
So I was dragging all day today. This desk jockey is plain worn out from a week + of physical labor. Anyway, got the body lift install. Only damage was an O2 sensor wire that didn't want to stretch. I still have all of the ancillary work to take care of, the drivetrain lift and exhaust replacement being top of that list.
I did the drivetrain lift in the '95, and it makes the body lift process much simpler. It also works really well with the 3" BL. I simply made standoffs out of 2x4 tubing that go between the motor mounts and the frame horns, and between trans mount and cross member. Doing it this way add a bit of rake to the drivetrain. This is because the motor mounts are sitting at a 45* angle, so the 2" height of the tubing nets you 2.8" engine lift. With the additional suspension lift this time around, I am curious if I will run into driveshaft problems.
So here is where I ended up today:
For reference, Josh is about 5'10" these days.
. Once the test drive is successful, I will pull it out again and finish the job.
