project photo hosting
Trumansburg, New York
Well, I have obtained a used Safari Turbo system - intercooler, unichip, etc. - and will soon start the install but I've had a couple of folks say they'd be interested in seeing all the parts as they go back together and onto the truck. I've got a digital camera and will definitely be taking photos but not sure how or where to post them for others to view. If anyone has input/ideas please let me know. Right now it's just a big box full of disassembled parts and I really don't have the $$ or time to tear into immediately but thought I'd test the waters about how to let others check out the install. Oh, and of course offer free advice on how to proceed. Thanks in advance.
Mike R.
If you just want a place to dump the pictures where you and others can get to them shoot me and e-mail...I have several domains setup at my house on my home server.
The pictures would be something like http://clownmidget.fzj80.com/pic1.jpg, etc I have fzj80.com so anything you want xxx.fzj80.com...
Just like Kumar has his page http://kumar.fzj80.com
Let me know, I'd help you setup a page and all that if you wanted...everything free ofcourse...
Later.
Mark Brodis
mabrodis@colorado4x4.net
Junk said:
Same goes for any fugly mofos.
HEY!!!! I resemble that remark! :flipoff2:
:cheers:
Thanks for all the replies. I'll get around to some photos this weekend hopefully. Still have to pull the s/c off. Anyone interested un-installing one :(
clown - keep a listing, please, of everything you gotta put back in. Thanks. Also would be curious to know if taking it back out changes any of your vacumn flow as I couldn't find it anywhere in the manual but it seems like the sc changes it.
s/c Un-Install
Junk, I just sent you an email to "yourLandCruiser" with photos and stuff. There is a change in vacuum flow and I'll post it later.
<edit> Mark, I sent them to you too. Mark has a pdf from George S. with the specs on building your own sst for the crankshaft pulley.
Short list of what you’ll need:
(1) large coolant hard line (can’t remember what this is called right now) that runs along the top of the exhaust manifold. This also has to have the gasket replace each time that sits on top of the thermostat housing.
(2) small #2 coolant bypass hard line that runs from the underside of the throttle body to front of block (where the s/c belt tensioner goes. George S. correctly identified that you could remove this non-destructively by loosening the distributor, but it helps to have it loosened enough to not only rotate it but pull it out ¼” or so too. I also had the alternator loose and I think that helps too. It can be removed and installed this way but it’s like one of those Chinese puzzles.
(3) brake booster nipple that goes on the intake manifold. Replaced with a allen (5-mm) plug with s/c
(4) intake hose from air filter assembly to throttle body
(5) original radiator cooling fan
(6) original radiator cooling fan mounting studs. Longer ones were used on the s/c along with the aluminum spacer to move fan our closer to radiator.
(7) Hoses. Lots of the vacuum hoses were cut, replaced, etc. Most importantly was the brake booster one. It’s a really odd size and you cut it to install the s/c, and what’s left won’t quite make it back to the nipple installed on the intake manifold. I had a hard time finding it sold by the foot.
(8) Throttle body gasket.
(9) Bolts. It helps to go through the s/c install manual to realize what was re-used. The two long (lower) and two short (higher) bolts holding the throttle body on are easy to forget.
I'm sure I'm forgetting other stuff but right now it all is running fine except the obvious change in performance. As for that, there has been a lot of discussion about the stock setup, the supercharger, and the turbocharger. Pretty soon I'll have experienced all three on the same truck with the same setup but for now I can say the supercharger definitely feels like it added the most right off the line from 1000 rpm. I haven't seen the power curve of this supercharger on the 1FZE compared to stock but it feels like it must taper off a bit once you get above 3500 rpm. But I do know that from a stop or trying to go over a large rock you can feel the absence of that supercharge :(
The only bonus I see from going back to stock is the amazing amount of room in the engine bay. There should definitely be NO complaining about working on your truck if you don't have dual batteries and a s/c or turbo stuffed in there.
Mike R.
Thanks again for the pics clownmidget. Unless you object, I'll toss them on up the site so they can be all be posted.
Junk, that's fine. I'll start shooting pics of the turbo stuff this weekend as I get started. Anyone know anything about cleaning turbos and associated plumbing? Mainly the outside but what is safe to spray in it as far as a cleaner? Throttle body cleaner ok? Maybe post a new thread on this but if you know pm me, please. Thanks
Mike
