Project Krusty - Not a Resto! (1 Viewer)
Sure, if it doesn't leave you short a floor. :)
OK, changed my mind, call me what you will............
Stock is easier. Put a 25 rear in, and swapped in the lock right. Drivetrain done. :rolleyes:
So Jim now that your going stock what about the PTO winch? Or were you just putting a PTO box on it. You might as well just send any PTO winch parts that aren't being used on the green one my way.:rolleyes:
Your probably better off getting that pink SM420 out of there or other every time you turned around you would have found a pair of pink panties hanging off your mirror. You could of just put a Lexus badge on it and called it a LX390, metric size of the engine, okay I rounded up a little sounds better than 3878.
John
Find me a PTO box.................I'll put it in.
Just want to get it done......I'll accessorize it later. :D
Find me a reversible PTO for the SM420 (like the Cruiser PTO)................I'll take it. :D
i might have what your looking for i take a pic and send to you ..
kevin
Well, this sucks, and this is the good rear tub! :rolleyes: :crybaby:
Should rename this thread IH8BODYWORK.
Welded in a piece to work off and get started.
Bent up a couple pieces to make a rear channel. I was going to buy one......... but I finally got started so I kept going.
You being safe welding that galvanized?
Lots o' ventilation and a respirator................but I do that anyhow. :smokin:
Maybe should have bought this after spending a day making this one........
Not too bad............somehow made it about a 1/4" too tall though. Oh well. :rolleyes:
Patching, patching, patching.......................:rolleyes:
I'm no master craftsman, but this piece of work from the previous owner had to go. If I keep up at this rate, I may even get the two halves tacked together someday. :crybaby:
