So I've been messing around with ideas to supplement my cooling system on crazy hot days. Now the project is far from being completed or for that matter tested but I figured I would share with you to get your feedback and any suggestions you may have. Went to lowes and picked up a run of the mill portable misting system with six atomizer jets, then on to northern tool for a water pump and assorted fittings.
I cut up the misting system and removed the fitting and sprayers. Then roughly measured the length I needed to add a row along the inside of my grill.
Now this pic is just a rough mock up for testing. I mounted the sprayers to the inner groove of my grill using the highest quality zip ties I had
So far it seems to be awesome. I've got to finish the wiring which is connected to a momentary switch in my cab. The pump pushes up to 1gpm at 40 psi. But with the six nozzles attached it takes 11 minutes to go through 2.5qts of water and properly soaks everything. I'll post up more when I get the smaller bits finalized and get some real world testing but so far I like it.
