ramangain
Clarksonian disciple
Don't use your master- stash that somewhere safe now that you have valet keys.
Glad it worked out for you
Resolved. The guy used EZ-Flasher. Looks lie it can be found here: EZ Flasher
He was able to quickly read my valet key, then created 2 new little chips that I merely inserted into the keyfob, both are working great now. $250 and I'm done.
I'm no locksmith, but I don't think he is either. He just has a cool tool that gets the job done. Kudos
Please send a linkI have a cheap Chinese tool that will clone keys. Paid $29 for it. The chips are a couple of bucks each.
Indeed that is an eye full, so to recap and simplify your details please clarify a few things. I gather the LC started and ran fine before the A/C compressor swap? During the time it was down for the repair the known working key was lost? Your second key, which is questionable, does indeed turn out the security light upon inserting into the ignition (either turns out immediately hence a master, or within 2 seconds hence a valet)?
If all is true above, I'd go back to the area of the repair and not complicate concerns on the immobilizer just yet. In all the wrangling you did to extract the old compressor you might have disconnected a sensor that needs some attention. For instance, one of those is crankshaft position sensor. It's in that area (visible behind the oil filter and mounted behind the flywheel). The LC will crank but won't start if disconnected. If during the repair you pulled and reconnected, check it again, disconnect it and hit it with some WD-40 before re-seating the connection. Also check the camshaft position sensor connector and do the same. The sensor is not visible, but the connector is visible outside of the driver side timing cover (black and round).
Note the battery going dead is not a red flag. The alarm normally sounds when the battery is reconnected and it has no impact on the immobilizer.
