Priming engine for a new turbo ln130 (1 Viewer)
canada
Hey guys. Just in the process of installing the new turbo and was wondering what fuses you guys pull to prime the turbo or if you just add oil to the inlet and turn the turbine before installing/starting?ct20turbo
I don't recall there being a turbo prime procedure in the FSM.
you could just inject some oil in the turbo inlet if you are worried and then idle the engine.
you can disconnect your fuel solenoid on your fuel pump so your engine will not get any fuel and start and prime like in the video.
