SOLD MAJOR PRICE CHANGE! Conqueror 440 Extreme (1 Viewer)
$22,000. We received our new trailer and shook it down and need to get this gone. This is likely the best deal on a Conqueror you will see.
Located in north Georgia. Can tow to meet you somewhere if you like (no charge to AL, TN, NC, SC).
This is a 2016 Conqueror 440 Extreme that we have been using for overlanding and remote basecamp setup. It is a highly capable, compact, and very durable trailer from South Africa. Not many are left in the US! This trailer is DOT legal and registered and titled in Georgia.
The trailer has an enormous amount of features and capabilities. It has independent trailing arm coil suspension with Fox shocks and limit straps, steel construction with skids. The trailer comes with a VERY long list of goodies, including a heat pump (with heat and AC on generator or ground power) as well as a 12v propane furnace (no generator needed). Provisioned to take solar or anderson power from a tow rig, ground power with long cord, it has a built in battery management and vehicle management system with breakers and controls (including a wifi AP that can be used to control the trailer!). 40L of water on board with a pump, on demand heater, and hot and cold at both the kitchen slide out and the tire swing out shower enclosure. Darche 270 awning on driver, 23 Zero 180 awning on passenger, OEM awning over front slide out. Full kitchen slide with dometic cooktop, 83L snowmaster dual zone fridge/freezer, and drawers and storage for cooking and serving. Full pantry with a swing out door with more counter space as well as a bar to store wine and liquor bottles in transit. Has 2 queen bed pop outs. 3 storage bins (one is occupied with the heat pump and AC). Pop up roof, stabilization legs front and rear, and a mechanical drawer for longer items and tools, supplies, etc. 40 lbs of propane tanks included. Generator NOT included (but could be added for additional $). 33" tires (STT Pro) and 17" Toyota steelies. Spare has a bearing on it as spare. You won't get a tougher more versatile trailer. Almost none are available in the US so this is a low cost entry to a very high end offroad trailer. Upgrades have been done to the water heater, adding extra lighting, USB power, and more. Tows well behind our GX470 and weighs around 3700 lbs dry. Photos and video tours are possible for serious buyers!
Only selling to get an RV.
Someone asked me if I had the OEM awnings available. The easy answer: I would never do that to you. They are horrible. They take forever to setup and weigh a metric ton and also won't stay waterproof or store well at all. I cut off everything OEM awning on the sides and had outriggers built to hold modern 270 (driver) and 180 (passenger) awnings instead. MUCH better.
Bump, updated price (lower).
Bump again for the lowest price. Let's go!
Showed it this weekend and they paid cash onsite. Sold!!!
