Power steering
Portland, OR
A power steering question for everyone. I think mine is starting to go out. I replaced the fluid with Simpson last month. It still steers hard and feels like it's getting worse. How can you tell if it's the box needing replacing or the pump? Can the pumps be rebuilt or is it a waste of time?
Replace with a new OEM pump -- if it needs replacing.....Many rebuilds and aftermarkets don't last very long. It's a crap shoot, some do and some don't. An OEM PS pump can go 15+ years, so you get what you pay for.
PS pump gets filled with AT fluid, not PS fluid like some other automobiles. Not sure I know what Simpson is, but if it's not AT fluid, then this might be cause for some of your troubles.
Would be helpful if you could describe "steers hard" in a little more depth. By hard do you mean it requires a good deal of physical effort to turn the steering wheel?
When the PS gear box wears, the steering tends to get "loose" or feel sloppy. By your description, I would say that your PS pump is failing and not providing adequate hydrolic pressure to drive your gear box, hence making your steering feel "hard". Overtightening the adjustment screw on the PS gear box can make it "harder" to turn, but it's more of a binding sensation rather than a constant resistance.
HTH,
-dogboy- '87 FJ60
Put your tire against a rock or a tree or a concreete bumper in a parking lot. Try to turn. If the wheel turns some without the tire moving the box has slack in it and needs to be rebuilt. If the pump groans really loud or makes other wierd noises and the wheel tries to turn but seems weak the pump needs to be replaced. westtexasoffroad.com rebuilds pumps for a good price. They do good work.
The pump doesn't groan, leak or make any loud noise. It has just has started to be harder to turn, especially at slow speeds like in a parking lot. I replace the belt s month ago and the tension is good on it.
