At low rpms, my power steering does not work at all or at least very little
. Unfortunately it's at low rpms when I need ps the most. When I have the LC in neutral and rev the engine, the ps comes to life.
I have checked the fliud level in the reservoir and it's where it should be. I also don't have any leaks from under the truck and the things look dry around the pump. The gear box is also free of any leaks. The ATF looks a little brown (maybe it's a little burnt). Would just flushing the system work or is my pump going bad? Do I need to rebuild it or is there another problem. I hope its not a valve in my gear box
Any help will be appreciated.
