My4x4FJ40
Open 6 days a week
Are the fj80 power steering hose fittings 16mm and 17mm
Guys I'm sorry I wasn't clear and what I'm looking for the fitting that screws into the power steering gear the threads on the gearbox not the size of the wrench. I'm putting - 6 power steering lines and I need to know the fitting size for the gearbox if I'm not wrong its 16mm and 17 mm just trying to confirm
Any bugaboos or having the fitting adapter spin in the pump when you changed yours?
I'd take it down to a hydraulic shop to have them confirm it. Don't trust the interwebs for that! Why are you going AN-6? They're pretty yes but a competent hydraulic hose specialist can make some outstandingly durable lines that should last into the next ice age in something as relatively low stress as power steering.
I'm all for self reliance but I've never had a power steering hose that wasn't ancient and crusty fail catastrophically. But I look forward to the LQ9 powered vehicle write up. What transmission will you be using? 4L80E trans with an xfer case adapter?
