build thread of (ole red)
My4x4FJ40
Open 6 days a week
Greeneville Tenn 37745
well to start off I have a 91 fj80 that I have installed ARB lockers front and rear installed a full floater in the rear built the front axle and installed fzj80 front brakes and asin lockouts. next to come is 345 horsepower 380 pounds of torque lq9 6.0 to be followed by 4l65 203 gearbox to split case in which I already have built up .
Subscribed.
Care to share what all you've done to the LQ9? Cam, heads etc?
BONE STOCK
the only thing that I might have to do is run a Camaro intake and only if it's too tall a profile for the truck intake to be used.
I may also use a Camaro oil pan if I have front driveshaft clearance issuse but I'm installing a 3 inch lift so I hope that takes care of that
Done some work on the 203 shifter today hoping to be able to use the factory 80 hi/lo shifter to operate the 203 case. cut off the gaudy rear bumper. ordered some late model split case flanges from Georg so I can use my factory 80 drive shafts
I see you rolled it back in the shop to do some work on that rear bumper. Looking good Lee.
Looking forward to the 203 tech, putting one in my FJ62, and looking forward the LQ9, putting one in my other FJ62 :)
Man, those are some good looking wheels, Lee ;) Looking forward to watching your build.
Hope you get some work done buddy. Let me know if you need anything. I have a ton of work to do but I don't mind helping a friend out.
Out of curiosity could you tell me what the total length of the GM trans to rear flange of the split case is?
I should be going to the shop tomorrow and I can check them for you
QUOTE="RockJock82, post: 10071530, member: 61189"]Out of curiosity could you tell me what the total length of the GM trans to rear flange of the split case is?[/QUOTE]
I
I[/QUOTE]
44.25" from belhousings to rear flange.
Lee, its time for some updates !!!! What have you done to it lately?
my front mount for the LS engine come in and they are adjustable so I hope I can still use my LS 7 headers
