[quote author=sjcruiser link=board=2;threadid=10744;start=msg96566#msg96566 date=1075338654]
Wayne,
Here's what I would do:
. Syphon out old fluid in reservoir.
. Remove the res. and clean it.
. Put the res. back; reconnect the pressure line but plug its return line.
. Prefill the res. with fresh fluid to prevent air introduction.
. Connect a clear plastic extention line to the return hose and put it in a waste container.
. Pull the EFI fuse (or an equivalent one)
. Turn the wheels to extreme left or right.
(You might wanna put the truck on stands when doing this)
. Have someone crank the engine as you filling up the res. with fresh fluid.
. Now turn the wheels to the opposite side & re-cranking & filling.
. Once the fluid is clear & clean as desired, reconnect the return line.
. Refill the res. slightly above the max. line to accomodate the fluid lost in the return line.
. Restart the car - turn the steering wheels side to side (extreme) & watch the fluid level; refill if neccessary.
Frank.
PS: If the truck does not start after all this, put back the EFI fuse
( forgot to mention that above)
[/quote]
One thing I'll add to this. It seems that a significant amount of tiny air bubbles are still introduced into the system because when the return line is connected, the one big air bubble that is trapped there is blown through with quite a bit of force and creates the tiny bubbles in your system. Other have stated that after a few days of driving, they seem to work themselves out. They haven't yet in mine, but I seem to have quite a bit more air because I didn't pull the EFI fuse. Trust me, it's way too much force to keep up with. (I posted the same question 2 weeks ago and got slapped around even though I couldn't find anything back 600 days until ID gave me his username....but that's a different story.) Anyway, I think that if after reconnecting the return hose if you rocked the steering wheel back and forth from lock to lock, or ran the ignition once more w/out the EFI, you may be able to work that big bubble out in one piece. Just my 2 cents, got to prove it still this weekend.
