Hello Everyone!
I'm (illegally) here because the power antenna behaves strangely on my 100, but I think the 80's (wish I had one) have the same thing basicly. Please be gentle with me
I already have an IFS truck, so can't take any more bad things
So my problem is that when I power on the radio the antenna goes all the way up as it should, and comes down as it should when I power off the radio.
BUT! The "down" manual button doesn't work. The antenna is all the way up, radio is on, I press the down button and nothing happens.
If I press the "up" button, it will try to spin the antenna motor, then a relay clicks a couple times and the "up" button gets disabled as well - so until I powercycle the radio (antenna down, and then back up), nothing will happen from this point on if I press the "up" (or the "down") button.
So it's almost like the relay believes that the antenna is all the way down even when it is all the way up.. And after I press the "up" button and the button gets disabled, it's like the relay thinks the antenna is both fully retracted and extended at the same time?
And then the really strange part: If I disconnect the antenna assembly from the harness, both the up and down button will click the relay as it should.
Thank You in advance for all of your thoughts!
