Media Post your wheeling damage pics
Photo/Video/Audio threads
Good place to use a spotter….
Yes indeed!!
With the recent flooding rains down here, several spots had changed a bit. Coors and Bud hill was the worst, SOB was okay, the road from davils lane SB after SOB was washed out and impassable to Notch TH and southern backcountry camps.
The floor of Du-Pont narrows and changed with run-off, altering route a little....
If only they could be as easily found as in years past 😔 Would live a set for my LC.
Find some with damaged rings, I'll send ya some E&E rings!
Oh what?! I must've missed you do the rings. I know what I need for my RWs. Sick of the no draining
No issues with draining on these.
are the bolt heads recessed? cause I see those getting torn up very quickly if they aren't protected. the bolts on the current rings are jacked up from rocks.
The bolt heads are not fully recessed, but cheap to replace. ~15 cents each from fastenal. If you want them fully recessed, the ring would need to be thicker by a couple mm.
Quick drainage test
Minor gnar. Hard to get a socket on the rear diff plug when there's rock and metal ground into it. At least it didn't back out the bolt like others had expereienced.
Who owns the LX570 getting its tailgate ripped off with a recovery strap on YouTube. It makes me cry every time I watch it. Unnecessary roughness.
Link to video?
That’s just for the clicks, they aren’t even in any type of position requiring a yank. I’m guessing that tailgate was already damaged or covered in falcon poop.
Time to touch these back up after 2 off road events.
Could never get the Bud Built Edit "Trail Tailor" LCA skid to sit flush on driver side like the passenger side. Took a beating at Windrock, TN. Once the 2 screws were ripped off it bent downwards and became a rock catcher. Took off before by next trail event. I won't be replacing and didn't see them listed on Bud Built site anymore.
