prharper
GOLD Star
Aren’t those Trail Tailor pieces? I don’t believe Bud ever finalized a LCA skid for the public. His prototypes don’t use screws as an attachment method.Could never get the Bud Built LCA skid to sit flush on driver side like the passenger side. Took a beating at Windrock, TN. Once the 2 screws were ripped off it bent downwards and became a rock catcher. Took off before by next trail event. I won't be replacing and didn't see them listed on Bud Built site anymore.
View attachment 3766057View attachment 3766058View attachment 3766059View attachment 3766060View attachment 3766061
I have the Trail Tailor RLCA skids. I put them on after I chewed up the bottom of one of mine a bit, and figured the extra protection would be wise since those mounts can only be welded on if damaged. They were a PITA to install - I needed to use the jack and a BFH to bash them into place. They seem to be the same size/design and mount the same way.Could never get the Bud Built LCA skid to sit flush on driver side like the passenger side. Took a beating at Windrock, TN. Once the 2 screws were ripped off it bent downwards and became a rock catcher. Took off before by next trail event. I won't be replacing and didn't see them listed on Bud Built site anymore.
When lifting you typically will end up with your rear axle slightly cocked, so ironically this might actually straighten your steeringTook a few good hits on LCA at Windrock, TN. Bent the @turbo8 LCA brace and arm. Truck drives fine but I will replace LCA soon, hoping for another good Toyota parts sale.
View attachment 3766070View attachment 3766071
You are correct John, thanks. edited post. I sometimes have a hard time keeping track of all my aftermarket parts and vendors.Aren’t those Trail Tailor pieces? I don’t believe Bud ever finalized a LCA skid for the public. His prototypes don’t use screws as an attachment method.
I'd re-sleeve the OE arms. Should be able to straighten them enough. And I'd prefer it to the adjustable aftermarket options for the 200.Took a few good hits on LCA at Windrock, TN. Bent the @turbo8 LCA brace and arm. Truck drives fine but I will replace LCA soon, hoping for another good Toyota parts sale.
Do you want something stronger?Took a few good hits on LCA at Windrock, TN. Bent the @turbo8 LCA brace and arm. Truck drives fine but I will replace LCA soon, hoping for another good Toyota parts sale.
Factory OEM are pretty stout.Do you want something stronger?
After seeing Toyota make some aluminum ones with oem style bushings, I went ahead and designed some and will machine them out of 6061-t6 aluminum. I can't get oem bushings but Febest makes replacement ones that I'll use.Factory OEM are pretty stout.
What’s a stronger option that’s an easy replacement ?
Icon was responsive and promptly replaced them without any issues.I like the SEMA ones which are thicker/reinforced in the center, but I still don't think this is an upgrade for our trucks. Yes aluminum is lighter but I don't think it has a significant impact on handling or performance.
My concern with aluminum is that it's less resilient to impact. I've known people (*cough* @laserturbo91 *cough*) to break (not bend, but break!) the Icon rear arms, which are made out of 6061. IIRC it broke closer to the mount. Personally I'd rather have one bend and mess up my alignment temporarily (but still be driveable) than to break and leave my rear end wobbling around.
It looks like a contributing factor was the links binding on the mounting points.Icon was responsive and promptly replaced them without any issues. View attachment 3770612View attachment 3770613View attachment 3770614
Not over torqued. You can see the indents into the links. The links were bottoming out on the frame mounts before the bumps engaged. This would put a huge amount of stress on the bushing end. I would say this is an icon design problem, unless your frame mounting points were modified.. If you’re saying it was over torqued, I’ll blame that on Mr T. I was in a time crunch so had a local dealership install the whole setup prior to a trip. If it bound up due to design, I’ve got nothing for that.
Good observation! And negative, no frame mounting point modifications.Not over torqued. You can see the indents into the links. The links were bottoming out on the frame mounts before the bumps engaged. This would put a huge amount of stress on the bushing end. I would say this is an icon design problem, unless your frame mounting points were modified.
Unfortunately, it looks like your links were installed backwards. The instructions also call for trimming the factory mounts.Good observation! And negative, no frame mounting point modifications.
Man, great catch!Unfortunately, it looks like your links were installed backwards. The instructions also call for trimming the factory mounts.
I assume they broke when going slow? That could have been very deadly mistake if those broke at speed.Man, great catch!
