Hey guys,
First, I wanted to say I've been lurking this forum for a few months as I searched for my LX and you all seem extremely knowledgeable and helpful. I'm excited to join the community. Now onto my problem...
I recently purchased my first 100, an 04 LX with 180k miles. I got a great deal on it because of an AHC issue, and I'm pretty handy so I figured I could take it on(with your help) or in the worst case LC swap it. My use will be heavily street biased, so if I can reasonably keep the AHC I'd like to. I've done some searching, but this seems like a relatively uncommon failure mode, so I wanted some expert opinions.
When the dealership posted the ad for it, it stated that the truck was stuck in N with the light displaying OFF (i believe flashing). By the time I got the car, the car was stuck in L with OFF flashing. If you press raise, it flashes N for a bit then stops. So basically sounds like it's in fail safe mode.
My understanding is that this is often a sensor or a sensor/signal wire issue, however when I pull up the service history, it seems that this was diagnosed as a Height Control Accumulator Failure by a Lexus dealer 15k miles ago, and the repair was declined. I have not yet acquired a Techstream to pull down the errors. Looking at the forum, this doesn't appear to be all that common, so before I go down that road I wanted to see how likely this is to be the cause of failure, or whether it might be the dealer looking for a more expensive repair that fixing a corroded connector.
I just picked up the car(I'm not actually home yet), so I haven't had a chance to really get under it to dig around, but I wanted to get some advice so I know where to start. Thanks in advance!
