Yes.are they really supposed to be adjusted with standard load/on the ground?
Yup, use the sensor to adjust the height. Once your hub to fender is set ....
Could you explain this to a neophyte? I’m just learning about this system and gobbling up everything I can, but I got lost here. Is this essentially calibrating the sensor once the heights are correct? (And if this is correct, how does one do that? I’ve got an FSM on the way - but not here yet.)
I’m trying to grasp the whole before jumping in on anything. The guys at ACC said my rear shocks were wet but not obviously leaking, so I’m trying to plan out steps to properly diagnose/repair.
When I got my 04 LX with 110K (july 2017) my AHC was working but my pressures were way off. TBs needed adjusting and the coils in back were way fatigued and too soft. I go off road a lot, drive way too fast, and like a little more stiffness, plus I tow a lot. I ended up installing Land Cruiser AHC springs, which come significantly stiffer than the LX springs. Bonus, the LC springs are a lot cheaper than the LX version. AHC pressures easily adjusted to factory spec with this setup. I have Been driving on the new springs for 30k miles now and I couldnt be happier. Even with the somewhat stiffer LC springs, the ride, on and off road, is still luxurious. If you go this route be absolutely sure not to use non AHC springs which are not compatible.Yeah for sure! Looking at my pressures it looks like new springs are in order. Is there a cost effective option out there for new LX springs other than direct from Lexus?
