- Year
- 2000
- Vehicle Model
- LX470
- Location
- Portland, Oregon United States
- Mileage
- 334500
- Color
- Black
Open to discussion on price. Make me an offer!
Solid and well cared for LX470, 100 series Landcruiser. Tons of time and money invested in it, full description of recent work below. High miles, but solid. Engine runs as it should, with no burning of oil. These are known for going 500k. Ready to build your overland rig, just add the wheel/tire package of your choice and you're good to go!!
All new suspension (Ironman Stage 3, with 2" lift), new factory radiator/cooling hoses, new steering rack and tie rod ends, new factor headlight lenses (Lexus original), timing components, water pump, CV axles...tons and tons of work has gone into it. See list below. Front seats showing their age, but have seat covers. Interior in good shape.
Lift kit gives you plenty of room for overside tires if you want them.
Body is in great shape.
Just passed DEQ. Tags are good until February 2024. Timing belt/water pump done in last 20k miles.
$13k OBO
Regular oil/filter changes.
Recent work:
Feb 3 2022: All new Toyota factory power steering rack and tie rod ends, power steering fluid change
Dec 2021: New Toyota OEM fuel filter and new OEM PCV hose.
Oct 2021: New headlight wiring harness installed (brand new Lexus headlight lenses installed early in 2021).
Sept 2021: Front differential fluid change
Sept 2021: Replaced both front CV axles
Sept 2021: New valve cover gaskets
August 2021: Install of Ironman 4x4 Stage 3 lift kit. 2 inch lift. Removed old hydraulic suspension. New shocks, springs, torsion bars, rear upper/lower trailing arms, differential drop kit. New SPC front upper control arms. New swaybar bushings installed.
2020: Brand new Toyota factory radiator installed. new hoses and fluid change.
Feb 2020: Throttle position sensor replaced, vacuum switching valve replaced
March 2020: New brakes, wheel bearing seal
Sept 2019 (at 313k miles): Drive belt tensioner and belt replaced, transmission fluid changed, lower ball joints replaced, crankshaft oil seals replaced, water pump replaced, timing belt replaced
$13k OBO
Recent work:
