$6500.00: No Trades please
1999 Toyota 4Runner SR5 4x4, auto, 3.4 V6, 4:10 gears, no locker. 242,816 miles
Not so good things first:
The goods:
4 keys and original key code tag for new keys if needed
2 key fobs (1 is an AJT-Designs)
A/C and Heat work perfect
Stock privacy cover for rear cargo area
Timing belt & Water Pump done at: 209,456 miles
Rear axle seals done at 209,456 miles
5 - 265/75/16 BFG KO2 with powdercoated OEM wheels with 13,600 miles
Flat Iron Fabrication sliders (welded on)
Brand new, full 4 piece, Savage Off-road skids (prepped/painted/installed)
Suspension: OME F: 881 R: 890 (2” lift front, 3” lift rear) installed at 229,228 miles
Sonoran Steel Adjustable Panhard Bar
1” diff drop
Interstate ED-18 Battery 8/04/2018
Stainless Steel brake lines with extended rear line
Rear diff breather ran up to gas tank fill door
JVC single din media player with 4: 6” Kickers in the doors
Front recovery points (no drings)
LED Headlights
Oil change every 3500 miles (changed at 242,816)
Lower Ball Joints changed at 209,456 miles
Radiator replaced at 209,456 miles
Interior is 20 years old but in good shape
Solid, fun exploring, off-roading, camping rig
Extras if I get close to asking price
Brand new Rocky Mountain Racks: Antero Half-Rack with 5 crossbars (not painted or installed)
3 spare OEM wheels beautifully powdercoated
Rago Fabrication ditch light brackets (no lights)
1/2” body lift (not installed)
Energy Suspension steering rack bushings (not installed)
Used OEM lower ball joints (good condition)
Radiator Hoses (used but good)
OEM oil filter
Rear hatch gas struts (current ones work perfect)
New AVS rain guards (current ones work perfect)
Front and rear brake pads/shoes (new in box) (non OEM)
Fumoto oil drain valve (not installed)
Fire extinguisher and headrest mount
Custom T4R antenna mount (not painted or installed)
Other misc bushings
A hug
More pics available
- Gas gauge reads full all the time
- Crack in windshield
- Drivers taillight is cracked but works perfect (been cracked for the last 4 years and doesn’t get water in to mess with bulbs)
The goods:
1” diff drop
LED Headlights
OEM oil filter
Other misc bushings
A hug
More pics available
