Wanted Portland- 60/70 series full float axle spindle (1 Viewer)
Portland OR - USA
  1. 60 Series
Hoping someone has a bent or otherwise damaged axle with one good spindle end. I have n axle with one bad end
If that doesn't pan out FROR makes new ones, Brian said he won't sell them separately from his complete axles but maybe he would for the right $$
Saw that thanks. There is a local company that can mig weld to build up the surface and machine it back down to spec. There is not enough room to repair the seal surface with this process though. Apparently they can make a spindle but the seal surface is right where it would have to be welded into the housing.
The 80 spindle fror sells appears to be one piece including the flange like a stock axle end. Probably not much use for 60 unless replacing both for a custom application. May not fit for other reasons since it’s for their own housing.
Another alternative, a 60 series axle works really well in a 70 series, just have to move the spring perches, they’re only about 2.5” wider overall.
@joekatana might have some complete 70 axles as well
