For Sale Portland 1985 Toyota Landcruiser FJ60
Year
1985
  1. 60 Series
Portland, Oregon United States
Mileage
213000
Color
rgb(77, 73, 73)
Outside Link
https://portland.craigslist.org/mlt/cto/d/portland-1985-fj60-toyota-land-cruiser/7472538019.html
Selling for $28,000. A beautifully refurbished and maintained 1985 Toyota Land Cruiser FJ60 with over $25,000 worth of restoration work completed over the past several years, including a new OEM five-speed manual transmission and clutch, new Old Man Emu suspension system (including steering dampener and shocks), new carburetor, new cooling system, new alternator and battery, fully refurbished brakes (front and back, including e-brake), and new 4x4 Labs front and rear bumper system. Other projects include a fully rebuilt front axle, full desmog, and premium Alpine 7-speaker audio system, Tuffy lockable console, dash pad, interior mats, USB ports front and back, LED dome lights, and anti-theft hidden kill switch on the inside.
On the outside, the Cruiser has 4x4 Labs front and rear bumpers with swing out tire carrier and gas/cooler carrier and high-lift jack, Australian Side Mirrors, Hella Fog Lights, H-4 headlights, and LED exterior lights, Yakima roof rack, and 2” hitch. Factory 16″ steel wheels are mounted with low mileage Bridgestone Blizzak W965 Winter tires at each corner, plus a full spare. The Cruiser comes with another full set of rims and Cooper Discoverer AT3 tires, with a full spare. The paint job is in fair condition, except for rust in the rear driver side quarter panel, per the photos below and a fair amount of oxidation on the roof and hood. Chrome and exterior body parts including chrome in good shape.
On the inside, the seats feature striped gray cloth seating surfaces in excellent condition, front heat warmers, and Dynamat sound deadening was applied to the roof, floors, doors, and rear cargo area. The top of the line new seven speaker Alpine audio system includes a Hertz 4x95W power amp, Morel Maximo speakers and 8” Excelon 8" Flat subwoofer in the cargo area. A three-spoke steering leather wrapped wheel sits ahead of factory instrumentation that includes an 85-mph speedometer, a tachometer with a 4k-rpm redline, and a combination gauge. The six-digit odometer shows over 213k miles.
The Cruiser is powered by a carbureted 4.2-liter 2F inline-six, and features 16″ black steel wheels, power steering, air conditioning, a rear cabin heater. It has been meticulously maintained over the years, including regular servicing with belt and fluid changes, and is offered with full-service records since time of purchase in 2014, a clean Carfax report, recent inspection report, and a clean Oregon title in the seller’s name. The Carfax report indicates no accidents or other damage and shows registration history in Nevada, California, and Oregon.
Stock or aftermarket Carb? Rig reads and looks like it's in great condition, would you drive it across country?
Hey there Ben. The carb was rebuilt in 2016 when I desmogged the engine. It is OEM, but called my mechanic to confirm. Engine runs great and always has. The longest road trip I took the Cruiser in was in 2018 when I traveled to a Wyoming and back fully loaded with bikes, roof tent, and kids. We clocked over 2k miles without a hitch. I’ve never broken down or been stranded. I would have no reservations driving across country with all the caveats that one is driving a 37 yr old car.
Hope this helps!
Rob
Interior and undercarriage pics?
Listing details
sting Details
• VIN: JT3FJ60G4F1128224
• 213,000 Miles Shown
• 4.2-Liter 2F Inline-Six
• New HOEM 55F 5-Speed Manual Transmission
• 2 speed transfer case
• Resealed Transfer Case
• Gray Striped Cloth Interior
• Old Man Emu Suspension
• High-End Audio Components
• Recent Clutch and Rear Main Seal
• Rear Heater
• Air Conditioning
• Power Steering
• Complete Service Records: 2014-2022
• Clean Carfax Report
Highlights
Exterior
• New 4x4 Labs front and rear bumpers with swing out tire carrier and gas/cooler carrier and high-lift jack
• New Australian Side Mirrors
• New Hella Fog Lights
• New H4 headlight conversion
• New LED exterior lights (front and rear running lights, front and rear turn signals, brake lights, back up lights)
• New OEM front outer door handles
• New rear windshield wiper motor
Tires & Wheels
• 2 sets of low mileage wheels – all terrain and winter. Include five tires and rims per set (includes spare) and 16” black steel rims
o Bridgestone Blizzak W965 Winter Tires
o Cooper Discoverer AT3 – all terrain tires
Suspension and Drivetrain
• Rebuilt front axle, including disassembling, cleaning, and painting parts. Clean front axle housing. Reassemble front axle with new gaskets, repack knuckle and wheel bearings
• Install Old Man Emu suspension system. All new springs, bushings, shocks, u-bolts, greaseable shackles and pins, steering stabilizer, and extended front sway. Install new rear sway bar
• Install new front and rear pinion seals
• Rebuilt front driveline and new CV joint
• Install new rear u-joints and balance rear driveline
• New OEM power steering pump, with new pulley and with woodruff key, and power steering hose and hardware regular service (flush, fill, bleed power steering system)
• Tightened steering – adjusted steering box, adjusted and lubed tie ends, new steering box input seal
Brakes
• Full rear brake rebuild (new shoe set, new drums, new wheel cylinders)
• Replace emergency brake cable and lever
• Flush and bleed brakes
Transmission
• New OEM 5 speed transmission and clutch. Includes installing new idler gear shaft. Idler bearings OK. Assembly t/case to 5 speed transmission with new gaskets and seals. Clean and paint bell housing, flywheel cover and crossmember. Clean transmount, clutch fork and bearing hub. Install new engine rear main seal, pilot bearing, resurfaced flywheel, clutch, and throw-out bearing.
Cooling System
• All new radiator, water pump, thermostat, hoses, gaskets
Engine / Electrical
• Annual tune ups, grease, fluids replacement, gaskets
• Full desmog
• New OEM starter
• New “Mean Green” alternator
• Fully rebuilt carburetor, replaced carburetor cooling fan
• New belts, cleaned pulleys (P/S belt, A/C belt, Water Pump)
• New oil pan gasket
• Reworked and replaced battery terminals and new battery
• New motor mounts
• Anti-theft kill switch mounted on dash
Interior
• High fidelity seven speaker Alpine audio system with Hertz 4x95W power amp, Morel Maximo speakers and 8” Excelon 8" Flat subwoofer
• Full interior sound dampening (Dynamat extreme/Cascade Audio Vblock carpet pad) – doors, side panels, floor.
• Rebuilt seat cushions and seat warmers – driver and passenger
• New dash pad cover
• New lockable Tuffy center console
• 3 USB connectors – two on dash (2.4a) one in center console for back seats
• Installed new front and rear carpeted floor mats and rear cargo area rubber flooring
• New LED dome lights
• New 3-point seatbelts for rear seats
• New tailgate struts
• Tinted windows (35% to legal limit)
This is a nice truck. I would make sure you cross list it on another site to get max value.
