I am sure that they doAs an also “not a lawyer”, do they have legalese for “off road use only”?
As a “not a lawyer” if it’s not hidden, it protects them. Now, if they promote the on road use in video without a disclaimer, that may be a different issue.I am sure that they do. If we have an actual lawyer on the forum, I'd be curious on how much that actually protects someone from liability
Nada on disclaimers on promotional their info/spec sheet (perhaps it's in the manual(s) that come with the portals; if so that's disingenuous). They do mention the stock ball joints and axles being "weak point", however. Sure makes me feel warm and fuzzy!As a “not a lawyer” if it’s not hidden, it protects them. Now, if they promote the on road use in video without a disclaimer, that may be a different issue.
I was the first one to put the 74 weld portals on a LC250 and all I can say is they tick all the boxes and are worth the money in my opinion.Anyone other than Dissent running or considering running the 74Weld Portal Axles on their LC 250?
I realize $20k is a ton of money, however, it seems to make sense when considering: Suspension Lift, Diff Drop, Re-Gearing Diffs, etc.
Have always been amazed by HUMMVEE's, Unimogs, and G-Wagon 4x4 Squared capabilities. Seems like you kill quite a few birds with one stone by using portals. Granted one has 4 gear oil changes to mess with along with the usual engine oil change, but seems superior for stability, overall clearance, driveline alignment including CV axles.
What are everyone's thoughts on this?
I can get my head around the cost, and the cost/value actually make sense to me. Not having the ability to self-repair to extricate myself from the trail or road is an issue for me. Maybe you already have a solution worked out? The Dissent guys broke a portal and the e-locker on the last winch hill at Fordyce; seems lucky as it was unlucky that they were at the end of the trail.I was the first one to put the 74 weld portals on a LC250 and all I can say is they tick all the boxes and are worth the money in my opinion.
I talked to Toyota and obviously an aftermarket part will not be covered under warranty by them, but as long as there aren't any modifications to the power train, the warranty is still covered. 74W basically told me they haven't established a warranty period for the portals because they haven't had a vehicle with enough miles where they see limits on them. They have a couple trucks with 30K - 40K miles and they still show now signs of excessive wear. They use a 1 ton unit bearing from a F-350, which is much stronger than a Toyota unit bearing, so as long as things are maintained (changing oil every 5,000 miles, which I do at every oil change, it really only adds about an extra hour of maintenance (especially if you have a friend with a lift)are you concerned that your 37" tires put you outside of the warranty?
I did buy the 100K mile extended warranty, mainly for all of the tech that still could cause problems.
Interesting technical note - the 2nd gen Tundra front wheel bearing is slightly larger than the F350 unit bearing. Not sure how the new GA-F unit bearings compare. But I thought it was interesting.They use a 1 ton unit bearing from a F-350, which is much stronger than a Toyota unit bearing,
