Replaced the factory radio with a Pioneer AVH-3700, unplugged the amp connection and every works. Did not hook up the blue/white wire. Now I have very poor radio reception. Radio reception was very good prior to changing the radios.
Correct unplugged and plugged into the radio. Did not change anything to the antenna, goes up and down with the switch on the dashboard.
My problem is that I lose sound about every 2 days (just sound everything else wotks), not sure if it's related to the amp? Which harness you use to bypass it?
I didn't connect the the blue wite either.
For the OP, are you talking AM or FM or both? If you've only been on one, check the reception on the other just to see how it is.
One troubleshoot is to buy a cheep $10 antenna from autozone and plug it in. If nothing changes then its your HU, if it gets better its in the existing antenna. Conversely you could try hooking up the stock unit and see if it still works. The coax could have been damaged during the installation.
