Plugs to fit holes where fender flares attached
Tucson, AZ
I ripped part of one of my 1997 Toyota Land Cruiser's rear fender flares off. Eventually the part over the rear quarter panel started coming loose so I took it off. I was wondering what size plug I should use to fill the holes in the body where the clips went? I'm thinking there has to be a flush fitting piece that would clip into the hole. It helps that my car is black so it would blend in.
You will Probably need different sizes as the holes are not uniform in size. I used some by Hillman avail at Lowe’s/depot. Had to pick up smaller ones for the bracket that’s riveted to doors once I drilled out the rivets. I added a dab of RTV to the back to keep the few lose ones tight to the body panel.
plugs were from lowes home improvement. Hillman #881199 variable depth push fastener GM $.80 per pair
I’d love to see the after photos.
One from the thread linked above.
