Self-admitted long time lurker here in need of some help! I have learned a lot about my 2001 with 260k miles from this board just by using the search, but I'm stumped on this one. Short version is I'm replacing cv axles and front brakes with a few other misc. stuff while I've got it torn apart. Bearings looked good so cleaning and repacking those along with new seals.
The claw washers on both sides had some pretty significant scoring so I ordered a set of those. The problem is the new claw washers do not fit past the threaded part of the spindle and not sitting against the bearing so I cant "load" the outer bearing. Washers were ordered (90214-42030) from Toyota and also looking at the ones that came out are the same way/size. The id of the washers are ~43.5mm and the spindle at the outer bearing is 45mm . Anyone run into this before? The spindles are the original and I even ordered a set of new Timken SET47 bearings just to make sure I had the correct ones. Anybody run into this before or have any suggestions? I was diligent in my searching of this specific issue, so if my search skills have failed me I will take my lashes.
