Wanted Placerville, Ca. Front & Rear drive shafts ‘69 FJ40
Northern California
Need stock front and rear drive shafts for 1969 FJ40. Preferably around the Sacramento Ca area to avoid shipping.
Thank you!
I’m sure @pardion will have this. @kevos37 too. I may be in Sacto in about a month, house shopping with my son, if you’re still looking.
Hi Vernon,
I was recently talking to a guy named JD in Fremont, not sure if that is close enough? Search CL East Bay with term “Land Cruiser”, main pic shows some early vacuum linkage. Can’t remember if he has a pic posted or not but think he wanted $200.
Good luck.
If there is any chance you have any floor shift manual linkage for 3 speed, I am looking.
Hey Vernon, I have a set from my 4/68 FJ40. I'm in Oakley, near Brentwood if that's close enough.
Hi Vernon,
Good luck.
I have a floor shifter (no trans shiftplate) and a freshly Por15'd trans cover if needed?
Driveshaft bolt size changed between 68&69.
Over a hundred to choose from.😉
Thank you for the replies everyone. I am going to start close to home and then move outwards from there. Again, thank you for looking!
Hello Oakley,
Will you PM with pricing for shifter and tunnel or post here? I really only need scraps from trans. cover for the flange area and could be from early or later versions. You are close so maybe shifter could be worth it?
Do you have any:
wiring harnesses
linkage components
Trans. Inspection cover.
Thank you
