Ok, so following some of the posts I see here, I replaced my door speakers with the Pioneer TS 6.5" speakers that fit. I also replaced the ones in the dash with 4" Pioneer TS. The head unit was replaced with a pioneer double din.
The door speakers sound like crap when they get even the slightest bit of bass, even with the HPF on. The dash speakers sound great. If I turn the unit above 30 (which isn't that loud), the sound cuts out and I have to power cycle the radio, then it says AMP ERROR. I believe it is overheating.
What do I need to be looking for? Is this is an issue with a factory amp? Shorted wire? I've double checked the door speakers and they are taped up and not shorting out anywhere, and the polarity is correct.
Any insight would be helpful. I'm considering just running speaker wire to doors to see how that sounds.
I'm also concerned maybe there are too many speakers and the factory Ohm loads are causing the amp to overload.
