I like it, but bang for the buck wise I think I'll get something like this instead:
http://www.ebay.com/itm/PINTLE-HOOK...ITCH-TOWING-10-000-lbs-Capacity-/181209195169
It adds a lot more versatility than the recovery point.
I don't see how the end of my snatch rope through a d ring in a pintle is any different than attaching it via d ring to the recovery point. They are bolted to the same crossmember with the same bolts, but you can also tow pintle or ball trailers. I've recovered a lot of stuck vehicles using a pintle hitch before (military and civilian).An actual pintle hitch is great but, not for recovery situations. Both the URB's and rear pintle hitch are awesome, we use the rear pintle recovery point a lot more than the rear URB's simply because its not under the vehicle......![]()
Thinking of buying a pintle hitch recovery point for the rear bumper of my 91... Anybody out there purchased this from Jonesys Offroad and if so any information about it? Thanks!![]()
I would not use a chrome hitch ball as a recovery point. They are known to shear off.
I looked at there site and couldn't find what you were talking about. Unless you were talking about the 5 ton pintle hitch for $70. If your just putting a pintle to the factory cross member I would not trust that for recovery. Just take a look under the rear end at how flimsy that thing is and you will understand why. Maybe good enough for towing the jet skis about but you will get a lot more force going on during a recovery.
If you are just wanting a pintle hitch go down to harbor freight and you can get one for cheap. I bought a 10 ton from the local for less than $20.
What do you guys think about these...does the four bolt pattern match the ones on ours?
https://www.expeditionexchange.com/dixonbate/
@JonesysOffroad any Christmas specials for Mud members??? Interested in a one inch body lift, some URBs and the pintle hitch set up! I won't know if this all works till I buy em and put it to use!!!!
