Hey we have a small group locally here. Looks like you work on a base, which one? I work on the Norfolk Navy base. Our section in the clubhouse VA/NC- Mid-Atlantic Toyota Land Cruiser Association
I'm in Suffolk, Va; the Norfolk area. I do wheel Crozet a lot, and plan to take this up there although I probably won't beat it up hard at first. That step/rocker panel behind the front wheels looks like it might need to be removed and armored up.
Again, thanks all for the warm welcome.I did read some FAQs before I posted so I get the greeting. I appreciate all the advice and I will look in to it.
Yes the tail pipe does exit the rear, I'll look in to moving the exit to the side at an angle maybe.
I will look behind the diamond plate and check it out. It's just screwed on with self tappers so not sure what's going on there, but the inside of the tub sounds solid when I hit it. It might be because the tailgate is diamond plate and they just wrapped it around the corner to make it match, but that would have been a dumb idea. Actually the tailgate is pretty neat, hinged at the bottom with two recessed latches at the top kind of like a tool box lid.
So I'll read up some more on stuff like the axles, I just thought the birfields wouldn't take much more than 33s.
As for the fan, I get that people wire it so it can be switched off for stream crossings. I guess what I meant is that it is wired directly to the battery and not switched to run with the key on. I have to turn it on everytime I start it and off when I shut it down. Kind of a pain, but not like I'm complaining or anything.![]()
