- Joined
- Sep 9, 2004
- Threads
- 187
- Messages
- 13,243
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Are you stock height or lifted?
OME 2.5" lift, says that above where I posted the pic.
Cheers
BTW, I have zero rub. I just bombed a gravel road last weekend, 55+mph for 30 miles. Aired down to 20psi and it was awesome. Almost got airborne off a cattle guard, suspension fully compressed, zero rub.
I have only had them since the 4th of July but I am in love. Excellent tire and perfect size for a 100. I am bias though, I did two trips to Panama and back on BFG A/Ts with zero issues.
I do not get the above post about running on pavement with 35psi. That seems way low to me for pavement. These are an 80psi max tire. I have ran them at 60psi and right now am trying 55psi rear and 50 front. My shop is all full up or I would just dial them in right for pressure. Which btw folks is easy. Put some chalk or dust or whatever you got on your shop or garage floor. Drive over it and look at the tread pattern. Adjust air pressure until you have a perfect tread pattern.
Cheers
There can never be too many KO2 picture threads imo. These tires rule, even for the 95% highway driving I do.
Before and after 285/75/16
ETA: I also came from 275 Michelin MS2s. Stock AHC susp.
Before: Normal height
After: Hard parked in High
I've never measured it but a roughly 2" difference b/w N and H is commonly quoted around here. This will vary somewhat as it depends on the health and set up of your AHC.
Where in NH are you btw? I grew up in Greenland.
what size spacers are you running?
285/75/16 KO2 with OME/Slee lift.
1.5'' or 2.5'' slee/OME kit?
