- Joined
- Oct 4, 2013
- Threads
- 1
- Messages
- 8
Long time lurker but this is my first post. I have a white 1996 fzj80 with about 235k on the clock. its been great so far. i got it a few years ago and it is my daily. I do plan to wheel it a some point but right now i just need it to not break as I recently went back to school and funds are less than usual. I do love this truck.
I have removed the fenders flares running boards and roof rack and did the monster liner with color matched white tint over the areas. I have done the PHH and recharged the air myself along with a lot of other little stuff. I try to do what i can myself but I am learning how to work on cars as i go. I have a new leak that appears to be coming from the heater hose to the left of the PHH. You can see my repair in this picture and the other leaking hose to the left on the other side of the 2 bolts.
The problem is that the top of this hose seems to run up to the top below either the throttle body or the intake manifold. Has anyone replaced this one before? I have searched but can't find anything other than the PHH repair stuff. If I do need to remove the throttle body i think I saw a thread on that but i want to make sure i am barking up the right tree. Here is another picture taken from the top. You can see the blue tape i put on the hose between the intake manifold pipes to the right of the center bolt there. Anyone have experience with this one? Can I just remove the throttle cable pulleys? What else should I replace while I am pulling stuff off in this area? I assume i at least need a gasket if i pull off the TB. I do not have the FSM but it is on order.
Thanks all.
Thanks all.
