PCV Hose #2 Leak
North Front Range, CO
I am getting some leaking from PCV hose #2 on the valve cover.
I have replace the hose and even put a clamp on it and I am getting oil leaking out around the hose.
I replaced the PCV valve.
Is it that the motor is just getting tired and there is some blow by?
When I replaced the grommet my seep-through stopped and that area is now clean.
Before hand it looked like yours though. Is that a new grommet, and if so is definitely in good shape?
naw not worn out you just need a new hose, it likely has a crack in it,
Nator, the grommet is on the other PCV hose where the valve is. no grommet on this side,
;p Good call. These are the mistakes I make when I wake up at 2:30 pm :lol:
The PCV hose is new. The old one did it too, that is why I replaced it and then put a clamp on it.
