Hey guys,
I failed my California emissions test a couple times with High CO, then I did a carb rebuild myself and finally passed smog. With the numbers below, I think I barely passed. My 1978 40 does run well and is a daily driver, but I'd like to know if the numbers indicate any issues with the rig that should be fixed. What do these numbers mean and what can I do to improve them?
My timing is currently set at 9 degrees BTDC and I'm running a stock distributor with an advance and retard unit. I recently fixed a crack in the intake manifold, disabled the heat riser, placed an insulator between the intake and exhaust manifold, adjusted valves, but I do have a slight exhaust leak due to a bent exhaust flange that connects to the manifold. I'm also pulling steady vacuum at 18 inHg at idle.
Thanks.
Thanks.
