- Location
- United States
OK, my gamble to make it to CM this year did not pay off. Took a chance on a cheap 80 down in CO Springs, the PO claimed to have just had the HG done, and it would not start but his mechanic said it just needed an alternator and thermostat. It was cheap, and I *really* want to make it to CM this year, so I took a chance and had it towed to Redline last week. Got the bad news text yesterday from Justin, water on the pistons, so the HG is either bad *again* or the PO did a bad job or he just never did the HG at all. SO...I got it cheap enough to at least break even if I part it out, but don't have the time or $ to throw another HG at it, so I am going to try and part it out quickly and find another 80 before CM. Yeah....wish me luck.
Overall a solid 80. It is a 93 that had a 95 engine put in. Obviously the locked axles are the biggest selling point. The tires are basically new so would like to sell the tires and rims together. Ping me here or timmbuck2 at gmail or 72o 243 2o92. The truck is still in the Springs...probably can not go drag it home until early next week, but if you are in that area you can always grab the parts while it is still there.
Would consider selling outright for $3k. Worth more than that in parts, or have Justin do the HG and you are ready to go.
Here is his original ad:
219,00 miles
Professional sprayed Rhino liner around truck that way you don't have to count the scratches on your fun day
POCKET FENDER FLARES (Bushwacker Does not Make these) ONLY 4 SETS IN EXISTENCE MINE ARE MADE FROM SAME FIBER GLASS AS STOCK FLARES
Hi-Lift Jack
DIFF LOCKS FRONT, CENTER AND REAR
Anti-slip Diff control
3rd row jump seats PERFECT CONDITION
REMOVED PLASTICS ON BUMPERS TO Accommodate MORE FLEX
STEEL TAIL LIGHT GUARDS PAIR (ALMOST IMPOSSIBLE TO GET AHOLD OF IN CO)
SAFARI ROOF RACK W/ BRAND NEW 2 HID HIGH LIGHTS
ORIGINAL RADIO
ALARM SYSTEM (FACTORY)
COMPLETELY LEATHER
NEW BILSTEIN GAS SHOCKS
TRAILER HITCH
HOOD BLACKOUT
CASTER CORRECTED
STEEL BRAKE LINES
2 Side mount CB FIRE-STICK Antennas (CB removed for Now)
Jerry Can and Mount
REMOVED Carpet then rhino lined in trunk space so my dogs can be in the back and not worry about mold growing (the 3rd row jump seats still go in as normal if needed.
219,00 miles I had done a MOTOR SWAP So now has 119k miles just didn't care to change on dash legally, which is a hassle and if the car isn't a classic why bother when it's a toy Motor came from a wrecked in the rear end 1995 FJ80 with 100k miles I put 19k on it, motor mounts were from old motor
1 OME inch Lift
Unique Only set in Colorado POCKET FENDER FLARES Bushwacker doesn't make these had made and shipped from Japan
Anti Slip Diff Lock Control
3rd row jump seats PERFECT CONDITION used maybe 4 times EVER
REMOVED PLASTICS ON BUMPERS and cut Front TO Accommodate MORE FLEX and the plastics are dumb
Hand Throttle Switch for Winch can handle up to 10,000lbs winch capacity (winch will be sold separately)
TRAILER HITCH
HOOD BLACKOUT
Hi lift jack
CASTER CORRECTION
STEEL BRAKE LINES
ALARM SYSTEM (FACTORY) no key fob --unplugged
COMPLETELY LEATHER
Original radio Works like the 1st day
2 new tweeters and speakers in the rear
Jerry Can and Mount
Great rock crawler project or if you fix starter great first car insurance as a high schooler was around $100/ month
I had my dogs in the back of the truck so I put lineX in trunk space
219,00 miles
Hi-Lift Jack
ORIGINAL RADIO
COMPLETELY LEATHER
TRAILER HITCH
HOOD BLACKOUT
CASTER CORRECTED
STEEL BRAKE LINES
Jerry Can and Mount
1 OME inch Lift
TRAILER HITCH
HOOD BLACKOUT
Hi lift jack
CASTER CORRECTION
STEEL BRAKE LINES
COMPLETELY LEATHER
Jerry Can and Mount
